1994 Ranger runs, then won't start
shaunal
My 1994 ranger will start, run just fine. When i turn off the engine after driving for a while it won't start until it sits for 30 - 60 minutes. Any idea what is wrong?
Won't crank over or won't run?
If it won't turn over check battery cables and starter cables for corrosion.
If it turns over but won't fire up, I would get some starting fluid and spray some in the intake and then try starting.
If it fires up but won't stay running then you have a fuel problem.
If it doesn't fire at all then spark is the problem.
I will assume it cranks just will not start. Could be a leaky injector. Next tine this happens push the gas pedal to the floor and crank it. See if it fires up
______________________________
sent from DROID Bionic using tapatalk-2. (Ranger, 1999, reg cab, 2.5, 5 speed, 2WD) (2006, Vibe, 1ZZ, Auto, AWD)
