1994 explorer manual trans swap!!!!!
indymadcaster
ok, folks I have an m5od and the manual trans case from my 1988 bronco II (it is a 4.0 m5od i rebuilt it and I put it in it)along with the manual shift transfer case with the big clutch 4.0 flywheel/ perm magnet starter swap
it is going in the 1994 explorer i have with a bad auto trans and electric Trans case......So question is what years and model clutch and brake pedal bracket under the dash do I need? :icon_confused: cannot find a 1994 explorer manual truck @ pick a part or will the one from the BII work????
I do have the 4.0 man PCM for a 1994 and all the stuff on the BII(clutch, flywheel, slave, master, starter) so all I need now is the pedal bracket.
many thanks
Indymadcaster
Take everything out of the B2??
looking at this it appears i can pull both dashes back using the clutch pedal, brake pedal and the clips and spacers from my 1988 and its cross shaft and put them in the explorer support bracket........................
