twfmvm
- Dec 13, 2015
Well. I live in texas. So cold has a different meaning. But even on what i was calling cold days ( 32 degrees F 0 degress C) the baffle still lets in too much air and i have 2/3 of the radiator covered.
i just feel like it has to be running in choke mode most of the time to be getting a steady 19/20mpg. Its as if i would need to block the rad or take the fan off (jk) just to have my engine running at its optimal temp. Or maybe it is running at the right temp. But i just have that gut feeling. I dont see why it would be air bubbles if the engine runs cold and the heater runs hot. When i run the heater the coolant temp gauge appears to drop as well (which would suggest the heater rad is fine as well as the gauge and sendor). Recently i never see the needle past 1/8. Usually it stays on the edge of cold and normal
Sent from my SAMSUNG-SM-G890A using Tapatalk
