1989 V8 swap neep help PLEASE
I have checked the the fuel pressure at the test port , it is reading 38 psi at the fuel rail. I checked the compression on the cylinders, the are reading 120 psi.
The spark plugs are wet with fuel after cranking motor over and I have spark at the coil and at the plugs. With the key to on the coil ( red wires) read 12 volt, with key to crank it reads 9.8 volts.
The coil ( tan wires) is reading 1.8 volts with key turn to on position.
The truck as been sitting since December with the gas tank full of full , does anyone think the gas has degraded and is causing a no start.
