- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
It's too bad there isn't a simple way for the enthusiast to reclaim coolant at home.
I didn't realize that there was a market for scavenged R-12, but it would make sense.
It looks like this system has been converted from R-12 to R-134a.
The original Nippondenso compressor has been replaced by a Sanden (typical aftermarket), and worm clamps on the compressor lines are another tell.
On the accumulator/drier, an adapter fitting is screwed onto the low pressure service port.
All of the other components look to be factory-installed AC, and not dealer-installed or aftermarket.
So if my system is fact an updated R-134a instead of R-12, what changes for my situation? Is it less toxic and also less terrible to let out into the atmosphere?
If my accumulator dryer has an adapter on it, is there a schrader under it and do I need to remove said adapter to gain access to the schrader in order to press to see if I have pressure/charge? (And what’s the adapter for?)
Or can I maybe open up one of the compressor’s two connections and test a schrader valve there?
I honestly don't know. But, to take a stab at it, R-134a has to be less harmful than R-12, or it wouldn't have replaced it. "Less harmful" is still not "good for the environment", so me personally, I would make an attempt (and pay) to get an R-134a charge recovered properly.
I've always heard that every time you vent refrigerant, a puppy dies (or maybe I've got that confused with something else . . . memory's getting kinda crusty).
Yes, and yes.
Originally the accumulator drier had a low side service port, with a Schrader, and the adapter was screwed onto the port. The adapter matches the service hoses used with R-134a, and it should have it's own check valve, but I can't remember if it's a proper Schrader-type valve.
It looks, to me, that under the caps on the compressor's manifolds (i.e.- fittings) there's likely standard Schrader-type service ports for the high and low sides. The high side should actually (and on the original compressor it did) have a safety overpressure relief valve.
Once you find a service port Schrader valve, all it takes is a quick press and release of pin to check if the system still has a charge.
If you find a competent shop or garage that does AC before you take anything apart, they may be able to tell for sure if it's been converted. Sometimes (rarely) there'll be a sticker noting a conversion.
Well the verdict is:If the refrigerant charge has leaked out (no pressure) all that you should have in the system is oil. The original factory oil charge was 10 oz., and basically the oil will be throughout the system. The compressor and accumulator drier usually have the most oil, but as any component is removed you'll get some oil running or dripping out. Freon will "cook off" or evaporate as a gas, except when a system is suddenly opened; this is like an explosive release, and the Freon will flash freeze flesh, and it's especially bad in the eyes.
No charge. Carefully equipped with protection and with towels laying over engine, I probed all 3 schrader ports. Absolutely zero activity, not even the faintest bit of oil or fluid or anything. Bone dry, all 3 of them.
So I guess it’s safe to start opening up and removing.
Isn't it right under the windshield, above the hood?
I actually have a real shop manual arriving later today so might be able to find this answer in there.. but what are the air “entry” points into the air system that this ja all part of?
I understand now that there is a blend door for mixing between hot or cold air, which I assume has a hard lever connection to the temp slider knob on the controls in cab.
Ok thank you! So I did test those two schraders on top of compressor and got no action. But you’re saying that even so, I still may have some pressure inside those hoses? Regardless I’ll be careful every step of the way.Good. That's one less (big) complication. The compressor is a good place to start your component removal. Slowly loosen the the flair fitting nuts on the two manifold fittings until you can wiggle them; no Freon discharge will confirm that it's empty. Easy to retighten if you do get pressure discharge (again, go slow). I think that these will be flair fittings versus o-rings on the compressor.
Yes; air intake is through the cowl slots and routed around the passenger side to the recirculating door up behind he kick panel.
That's a WINNER! I hope that you're getting the blue-cover, two book Ford "1989 Truck Shop Manual, Compact Truck" set. If so, you'll have all of the information that you need at your fingertips, and it's the single best investment that you'll make on your truck. Even on CD, you want this version manual.
That varies by year. On an '89 the blend door is cable operated on the control head, through a cam.
Once you have the real shop manual, you'll have an incredible amount of information, which should answer just about any questions that you have. Good move.
I'm intrigued by your wanting to add filtration to venting system. I hope that you pull this off, and I'd like see what you come up with.
>>> I recommend that you get images of everything before and during your taking things off, in case later you want to restore the AC system. Keep and store everything removed, if you can.
Good luck!
