1988 Ford 2.3 Air Intake Temp sensor location
1oldranger
Some one replaced the factor air intake on this vehicle. They capped the vaacum lines. However I am not sure what they did with the Temp Sensor that should be in the air intake. I suspected they may have pulled it from the wiring harness.
Does any one have a picture of where this is located or where it plugs into the wiring harnes? I see a 4 prong male that is open on the passenger fender well. I suspect that might be it.
Also is there a pig tail that can plug into this when I find one?
I saw an 88 at th bone yard today, but it had a MAF on it and no wirs going to bottom of air cleaner housing. I dont think this had A MAF originally. I could be wrong. Any way mileage in the cold is suffering . I suspect this to be the culprit.
Thanks for any help!
