1988 BII Build
calipers and extended brake lines are in. wirebrushed some place and painted them too.
1988 BII Build
more afro engineering lol
1988 BII Build
i move the brake lines to the back of the coil bucket. i just need to figure out how i want to mount them. it's just temporary right now.
started shortening the front d-shaft as well.
1988 BII Build
finished the d-shaft tonight
pass 1
1988 BII Build
threw on another bead just for good measure
1988 BII Build
got rid of the factory tire mount too, i'm gonna make a new one that'll mount to the bumper
1988 BII Build
yay, 4wd is back
1988 BII Build
got my new spring perches too, much beef there
1988 BII Build
the pinion angle is at 12 degrees now, looks much better.
i also cut the rear of section where the bumper will go yesterday
pass
1988 BII Build
driver
1988 BII Build
the front spring hanger nut broke when i was taking it out and i had to cut the bolt to get it out so i had to make my own. i used a piece of 1/4" flat bar i had laying around and welded a grade 8 nut to it. loctited it and put it in. worked perfect and it's no going anywhere if i ever need to take the bolt out again.
put a bolt through the nut and tightened it so it would be square and welded it up then painted it
1988 BII Build
1988 BII Build
starting on the rear bumper today, pics later
you mean that's not gonna work? shit, i gotta take it out again!
i started working on the rear bumper today, but it's cold as hell and raining and i drank way too much last night. usually i feel better after i start moving around, but not today. ugggggghhhhh.
1988 BII Build
1988 BII Build
both sides will have a piece that goes under like so.....i have to cut where the line is so it'll be level
1988 BII Build
then it'll get a receiver hitch, some bracing and some sort of tire mount. still working on that part
i just updated on sunday, gah! haha
i have been doing stuff, but i didnt think it was update worthy. last night i rented a ball joint press from auto-bone and got my driveshafts taken apart. the driveshafts use the same size u-joint, so i wont need to do anything fancy to get the flange to work.
i went and screwed up the old u -joint so i had to buy another one damnit. it was only $13, but still.
i'm helping my buddy with his honda right now, he needs a new alternator, so i gotta F with that after work. i'm gonna get a lot done this saturday though
Looking good man, i really like the cut rear fender look.
grassy-ass......i like it too, got the idea from the ultimate adventure b2. i'll be happier with it once i get it looking better. i need to trim a little more so the bumper will be level.
1988 BII Build
i really like how functional that cut and bumper is eddie... are you doing the matching sliders like the uab2 also?
perhaps, i may use tube or pipe for the sliders, still not sure. i've finally found some metal suppliers around here that dont charge an arm and a leg for metal. they're in a different county, so their taxes arent as high i reckon. what really sucks though, is that i could've made my radius arms for about half of what i actually spent on them. oh well, i know for next time now.
thanks btw
thought i was gonna get a lot done today.....NOPE.
my driveshaft is causing all sorts of problems. looks like i'm gonna have to pay to have my explorer shaft shortened. the old 7.5 shaft is too small to accept the ujoint needed to use the 8.8 driveshaft flange.
so then i decided i'd work on the bumper. i was almost through a piece of 2x2x.250 and my chop saw died. i had a 1 year free replacement warranty on it (up in april), but i had to stop what i was doing, clean up and drive over to the harbor freight. ugggghh. did get some stuff done though.....
1988 BII Build
1988 BII Build
1988 BII Build
got my receiver hitch while i was at harbor freight
1988 BII Build
more will be done tomorrow
