1988 2.0 Ranger with Holley 5200 timing question
borlax
I have a 1988 2.0 Ranger and I have all the stuff to put a Holley 5200 on it with the stock 2bbl intake. My timing is set for the stock 2.0 YFA 1bbl which I am running now with an adapter on the 2bbl intake. It works well. I saw in this thread:
http://www.therangerstation.com/forums/showthread.php?t=68462
On the 4th post by briansz, toward the bottom he says "Need to set timing as well". Will I need to adjust the timing? This engine has 75K original miles and runs awesome. Thanks
You don't really need to change the timing, but you can possibly get more power, and or gas mileage if you try different ignition timing (you can always set it back to where it was).
