- Oct 24, 2012
- Age
- 35
- Lafayette
- State - Country
- TN - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Tire Size
- 245-70-R16
Only way to get 2 O2 sensors is a newer ~94 PCM and the extra wiring involved. (Also usually comes with SFI and the CPS.) Could do an x or h pipe but those are usually even more in the way of the transmission. Flip the manifolds like a turbo setup and run the exhaust out the front?
My 88 had the triple function switch. Always thought 87 did too. Only thing I can think of for switch to the PCM is the for clutch pressed while rolling idle?
I used the throttle cable from my 91 Explorer harness donor. Since your clutch switch setup is different the throttle pedal might be too. If you have the cable from the 91 you could at least compare and get the approximate length.
RockAuto lists a sender for 87:
I'm not versed in AC myself but my understanding is that when a system is assembled there is a certain amount of oil to be used that isn't in those cans. I know they sell oil seperately.
Ohms Empty | 80 |
Ohms Full | 10 |
