Wanted 1987 ford ranger 4x4 5 speed ext cab rear drive shaft (complete)
ohio
Needed 1987 ford ranger 4x4 5 speed ext cab rear drive shaft. This is a 2 piece drive shaft with carrier bearing the transmission is an f146 5 speed manual.Some one really messed it up very bad. I would need the complete drive shaft plus the carrier bearing Im willing to pay shipping to ohio .Thank you for your time
Are you in a hurry; the yard near me has an 87 extra cab. I could grab it for you next time I'm up there.
Hello thank you for the response.
Yes/no maybe I would need it from the back of the transferrer case all the way to the rear end.Some one tryed to make a drive shaft and messed all up.None of are junk yards in ohio have nothing all newer stuff.But if you can put your hands on it i will pay shipping and how every it costs you. thank you
I would need this part its split bad and some one tried to weld it this bolts up right behind the transferrer case and this is were the carrier bearing is at. this shaft can be unbolted from the
56189
89FR,
The yard Ranger is an 87, 4x4 five speed (should be exactly corrrect for your rig); measure the length of that drive shaft just to ensure were both holding apples ..)
I understand you need from the transfer case to the differential.
89FR,
from flange to yoke it is 18 inchs or just a hair more
Hello Gaz i pulled the complete drive shaft out of rear and im going to need the whole thing some welded the ujoints in!!! So I thought to pass it along to you.From what i can tell this truck had an automatic in it and some did some bad stuff so. Thanks
