- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
lol thanks for posting the pic. So i should see if the bondo already on there peels off? Also, wouldnt sanding the stuff thats on there now not work because of the gap? Should i try and bend it back or will it break off? Also, wont the new bondo be noticably different on colour? I really want it to look cool, as if it was never therelol
Time to get dirty. You have to start somewhere, and it might as well be with the rust cover up. Do as The Bandit says and break out as much original bondo as you can, the new bondo color doesn't matter, it'll be covered with new paint. Sand the metal[or use a 4.5" angle grinder with a wire wheel attachment and USE SAFETY GEAR] so there is as little rust as possible then use rust converter before re-bondoing. You'll need sandpaper as well, and primer, and spot putty. Buy a book about your truck[ chilton's or hayne's are ~$20.00], it'll have a short section on rust repair as well as other stuff you'll eventually need to know. From looking at that picture, who ever did the repair had no experience either so yours will look just as good if not way better. I'm no expert on body repair, I'm sure others will help out more along the way.
Just DO IT!
Good luck
Richard
PS. I'm subscribed to your thread here and I will check back every couple of days if you need help. Maybe you could/should start a build thread too?
