- Aug 11, 2009
- Automatic
So I have a 1984 2.0 Ranger. The truck sat for several years and wanted to get it running for a project with my son. Got it running- had lots of blow by and no compression on one cylinder. Tore it apart- rings broken. Rebuild motor, have it and running but overheat light is coming on. Changed thermostat and still coming on. No coolant going through radiator so I am suspecting the water pump is toast. Heater hoses hot but upper and lower rad hoses not and no heat in coolant in rad.
195 degree thermostat. How can I confirm water pump? or could it be a air lock? how do u get rid of that?
Couple other questions
We have taken off all EGR, Pollution control and extra wires- want it simple.
does it matter if distributor advance vaccum goes to carb or manifold vacuum and same as vaccum pot on the choke- carb or manifold?
cheers
cheers
