BlackMoses
Hey guys,
While I own and love my 2001 Ranger, my dad has a Pontiac Fiero we're having a hell of a time getting it running so I thought you guys could help.
But here's the situation, we've got a 1984 Pontiac Fiero with the 2.5 liter Iron Duke that just recently tore up it's fiber timing gear on the camshaft. So after pulling the camshaft and pressing a new one on, in addition to replacing the distributor cap/rotor, spark plug wires, and ignition coil...we can't get this thing timed right to turn over.
The dots on the camshaft gear and crankshaft gear are lined up and the rotor is pointing between the 1 and 3 spark plug posts when cylinder 1 is at top dead center (and the timing mark on the crank pulley is at 0).
Here's a video to show you guys what's going on: http://www.youtube.com/watch?v=4R8dFQmKJrU
As you can see we're getting some backfiring through the throttle body and some air out of the exhaust but it's not turning over. We've checked the plugs for spark and I can see it getting fuel, and we've got the ECM posts connected with a paper clip in order for it to hold the timing, but it's still dead in the water.
Thanks in advance for your advice and help!!!!
