- Aug 6, 2007
- Shangri-La
- State - Country
- GA - USA
- Drive
- 2WD
- Tire Size
- Round
- My credo
- Alas poor Toonces; I knew him well.
Does anyone have any recommendations to check if this doesn't fix my battery draw issue? its a major draw to pull a whole battery to nothing in 3-4 days.
Terminals and battery cables all new, haven't found any shorts in wires. Brand new voltage regulator and starter solenoid. Fuses shouldn't pull that much off a battery in such a small amount of time right?
Big draw? Disconnect the battery ground cable. Put a 12V test light between the battery post and the cable terminal. A large draw will light the test light (could be real dim, or bright). Start pulling fuses, one at a time, and look for the test light to go out. Trace that circuit from the fuse cold side through to all of its components to narrow down the problem.
If it's a small draw, as in parasitic current draw; use a DMM (digital multimeter) set on your highest DC amps scale in place of the test light as described above, and use the same troubleshooting steps.
It will help your troubleshooting, if you can see your battery draw (as in with the light or meter), and also knowing how big the draw is. Then it's simply a matter of disconnecting circuits (as in pulling fuses, or disconnecting components) to isolate the problem. I have an '84, too, so I'm kinda partial to that vintage. What motor does yours have?
