91rangerxlt
ok im fixing to get a 77 f150 4 wheel drive with a 4 speed, and a 351modified. it has the 9 inch rear end, dont know what the front axle is anyway, how does the 351 m do powerwise something like 160hp. it has 3.50 gears and the guy said hes pretty sure it has limited slip. he also said it had a 4 inch lift on it from the factory, all i know is it sets up pretty hi and its only on 235s. how big a tire can i fit under here if it has a 4 inch lift. and is the front axle strong enuff to weld the diff. for river running and mudbugs. should i swap the modified out for a bigger bigblock or run it till it blows. let me know thanks.
