Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 57
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
Many of you know that I was in Kentucky to explorer the Kentucky Adventure Tour with the Vagabonds and our 25th Anniversary Fall Adventure at the Land Between the Lakes National Recreation Area, but I thought I would share the rest of my trip with you.
For me, this was multiple trips that all ran together. After our event at Land Between the Lakes, I headed north to Eastlake, Ohio where I spent 4-days visiting with my mom. From there I drove down to East Liverpool, Ohio and stayed with my daughter and son-in-law Ethan at The Coleman Farm.
Ethan inherited The Coleman Farm in 2021 when his father Jeff passed. Jeff inherited it in 2015 after it was willed to him by John Coleman. At one point the farm was 300 acres, but it had been split up and John owned 100 acres in the middle of it. Jeff had created a facebook page for the farm and would post videos about the farm and the things he wanted to do there, so after he passed, Ethan made a list of all the things his father said he wanted to do and set out to complete his dads wish list. He also wanted to preserve the history of the farm. It's really beautiful property and Ethan has a website and Instagram account dedicated to it. He also took over the facebook page and keeps it going.
Anyway....
I brought my Glock 22 (.40) and Glock 42 (.380) with me on the trip to shoot them out at the farm. I grabbed an EZ Target & Stand from Dunham Sports, and then found a spot to shoot at the farm. I liked this spot because there's a hill to the right, a hill and trees behind the target (and farm fields beyond that), and a wooded hill to the left. If you look at the photos, it looks like this would make a nice 2-stall range with a tree dividing them.
I managed to wash some more mud off of the Ranger while I was there, although it's still shows signs underneath that I've been mudding in it.
In the bottom level of that barn is a 1980 Pontiac Turbo Trans Am. Ethan's dad Jeff bought the car new in 1980. In 1985 the turbo went out and Jeff parked it in a garage with 44,000 miles on the odometer. When Jeff passed, Ethan inherited the car.
Ethan brought the car to the farm and parked it in the lower level of the barn so he could try and get the car running. Him and his friend Clutter replaced the plug wires, spark plugs, and just about every part in the distributor trying to get it to start, but the car still had no spark.
When I got there Ethan showed me the pickup he had purchased for the distributor, but when I looked at it, I realized that it had the wrong plug on it. I took an ohm meter and tested the stock pickup still in the distributor and it appeared to still be good, and I remembered that these turbo motors had a separate module that controlled the spark. I tracked the wires from the distributor and found the Electronic Spark Control module (ESC) attached under the front of the center console and disconnected it. Ethan had called the guy from TTA Performance that was extremely helpful and told us to cut the green wire for the G connector and the black wire for the J connector and connected them together with a butt connector which I did. After doing that I shot some starting fluid in the carb and it started right up when Ethan turned the key.
The problem now was that the car wouldn't stay running. Ethan had removed the fuel line going to the tank and stuck it in a gas can so the engine didn't suck old gas from the tank, but it wasn't pumping. I read online that the diaphragm in a mechanical fuel pump can go bad if they sit for a long time, so we replaced it. We checked to tank to see how much gas was in it thinking we had to drain it, but it was bone dry. Apparently, Jeff must have drained it when he parked the car. We poured 5-gallons of gas in it and after helping it start and run with some starter fluid, it was finally drinking from the tank again. But because nothing is ever easy, it wouldn't idle. At first, I figured it's because the turbo was bad, but then remembered that a turbo isn't making boost at idle, so the car should idle without it. I saw that the air cleaner had a 3-port plug on it, found the plug with the vacuum hoses that fit it, and it was now idling but not running smoothly. I suspect that it still has some vacuum leaks.
My goal was to help Ethan get the car running, and it now starts and idles, so I'm calling that a win.
I went and hung out with my friend Jon Dear a couple of times, had breakfast with my son and daughter-in-law while I was there, and we went back up to my moms on the 22nd and took her out to eat for her birthday. As soon as we got back from there (hour and 45 minute drive) I headed to Primanti Bros in Monoca, Pennsylvania to meet with @JohnnyO. JohnnyO wasn't able to make it to the anniversary event, so I wanted to make sure I saw him before I left in the morning. @sgtsandman didn't live far from there and joined us.
I took these pictures of the farm truck before I left on Monday the 23rd. I swear this is the longest bed I've ever seen on a Stock Ford F-150.
I knew when I left that it was 1,200 miles from here to my home in Texas, and that was going the most direct route. But I wasn't going the most direct route. No, I had other plans.
Rain was rolling in as I left Monday morning. Unfortunately, I needed to drive an hour and 45 minutes northwest to Akron to visit Ohio Drone Repair. Ya, I'm telling on myself, but we learn from sharing. Two days prior I had been flying my drone and clipped a tree branch. This didn't appear nearly as bad of a crash as the crash it had on the Vagabond trip, but it actually cracked the left front arm near the prop motor. I searched online and found that this business had the replacement part in stock, so my plan was to stop buy, purchase the new arm, and see if maybe they could repair it for me that day.
When I arrived I was impressed to find that this was a legit business with a nice showroom full of every size drone that you could think of as well as accessories. There were multiple employees as well, so this wasn't some small one guy business.
Brian looked at my drone and found that the arm socket inside the drone was broke as well. The new arm and socket were going to cost me $45. They could do an emergency 24-hour repair, but I wouldn't have it until tomorrow, and I was leaving Ohio today. They could stop the other repairs they were doing and fix mine, but it would be over $300 which was crazy expensive. Brian told me that if I had a soldering stick and small screwdrivers, I could fix it myself. He told me that there was a lot of glue to peel back and work around, and that it takes him about 4-hours to do the work because you pretty much have to take the whole drone apart. 4 hours for him would probably mean it would take me 8 hours. LOL. He told me that if I tried to fix it and had problems, I could ship it to them for repair.
Brian also showed me the DJI Care Refresh coverage I could have got within 48-hours of activating the drone. The 1-year plan is $59 and the 2-year plan is $89 and apparently if I had either of those plans, they would have replaced my drone.
At this point, my option was $45 and fix it myself with the possibility of buying a few tools or paying over $300 for them to fix it the same day. Then Brian offered me a 3rd option. Option #3 was to give him my drone, and he would ship me a brand-new replacement for $216 which included tax and shipping. Then when I activated it, I would have another chance to purchase the DJI Care. If you buy a DJI drone, get the DJI Care. So basically, it would be like I was paying them $171 to fix my drone and ship it to me ($216 - $45 parts). While I don't like paying people to fix things and felt like I could have probably fixed it myself, option 3 had advantages and just made the most sense to me. So, I left Ohio without a drone.
I had stayed in Ohio long enough and was ready to leave. I charted a course south down IS-77 to Charleston, West Virginia where I would pick up US-119, stop for dinner at Chick-Fil-A in South Charleston, and finally stop at the Best Western in Logan West Virginia for the night.
Anyway....
