16.5" Rim in Ranger Bolt Patter?? Any1 Make Them??
Lil Ranger
1995 Ranger
Im pretty Sure No 1 Makes a 16.5 Wheel in a 5x4.5 Bolt Patter, Right??
Only Reason I ask is cause I Like the 36" n 37" Hummer Tires,
n I can get my hands on 2 sets.. But No Rims... DAMIT!!!!!!!
Thanx,
Rob
Lil Ranger
No they don't make them, but you could get a wheel spacer/adapter and then find a 16.5 if you really wanted to.
Yea you would have to addapt from a 5.5 pattern. But also, do you plan to use thesetire for wheeling? If so what type of wheeling? If it involves airing down, you will run into problemswith the tires falling off the beads all the time. 16.5 wheels do not have a safety bead on the inside lip of the wheel fo the tire to "pop" on to like other wheels do. So if you do a lot of wheeling and don't have to run 16.5s cause you need brake rotor clearance or something like that. I would stay away from them.
