13b in ranger
Let me point out one of the most famous cars in history
The AC Cobra.
Particularly the one with the Ford 427engine...
Those cars have a well deserved reputation of being a fearsome automobile.
But the original ones were, to be polite, "somewhat less than successful as race cars"
they were really TOO powerful to be controllable and too nose heavy to corner well
the reputation of the cobra was almost entirely due to the earlier 271hp 289 powered machines.
Power is "nice" but too much power IS possible to achieve.
There IS such a thing as "too fast"
aircraft are often fitted with more powerful engines than that for which they were originally designed, Yes these retrofits are intended to increase performance
shorter takeoff roll, faster rate of climb, increased performance at altitude
often increased payload capacity, but one thing a more powerful engine rarely
does is to increases the aircraft's maximum speed.
Not that the engine couldn't force the aircraft faster but because in some situations
to do so would force the aircraft past the speed where it is stable and/or controllable
So while more power and or torque can increase acceleration the
speed where a ranger will decide enough is enough and try to fly
isn't going to change.
faster than 100mph in any ranger is simply an act of stupidity.
I've had my truck to 110, ONCE while it was still a 2wd 2.9
Yes, a tailwind was involved.
I don't have the 4.0 4x4 suspension "dialed in" well enough to have
taken it past 95 without worring that something important was about
to fall off.
Like the tread of my non-speed rated TRUCK tires.
Older mustang brakes? How much older?
Because the common way of retrofitting 5-lug brakes and wheels
onto an early fox mustang was to use 2wd ranger rotors.
The brakes I'd use would be 1995-97 2wd ranger brakes
along with the entire beam assembly, simply because it's real easy to bolt in.
as for suspension setup?
I'd go with soft rate springs and the stiffest sway bars I could find.
Infact I'd be very inclined to put dual swaybars on the front
The behind the axle swabar from a Gen1 then "tune" the front
by trying the different "thin diameter" front mounted bar from a Gen2
the Front mounted Gen2-up bars were made from 5/8" to 1-1/8"
And I don't know what kind of shocks would make it "right",
but I know Bilsteins aren't it.
I think fully adjustable race shocks would be needed.
AD
i understand the handling issue the trk gets light in a hurry, i had a speed wobble at 70 but went away at 75 in my 93 3.0 ext cab 4wd. my 2.3 ext cab 2wd however seems to handle the corners a lot better, prob due to ride height. to be honest as far as suspension is concerned id go w/ koyo fully adjustable coilovers if i could find a way to make them work, then install all wheel disc brakes if i could convert, either get the kit for the rear or do an exploder rear swap. id find similar yr mustang that had 4 piston calipers and slotted/crossdrilled rotors and stainless lines for added stopping power. stabilizing the rear end to keep it from swaying out like my 4wd did is the thing that always confused me, not much experience w/ solid axle setups. sway bars would help, shock tower stabilizer link would be awesome as far as stiffening the front end to keep the body from flexing and rolling during cornering. just some thoughts i had, feel free to ponder them.
I had to put a four link in the rear and a mustang II front end to keep my ranger straight at high speeds. When I first put my 2.3l turbo, I would go really fast, the rear end would kinda lift up and the tires would start squealing. That's interesting highway driving that gets old fast.
Now that it's bagged it's way better, drives better lowered. I think.
Turbo rotary would be great. the 20b-rew is triple wankel power with turbo. yum.
do you have pics of your suspension setup? im not very familiar w/ solid axle setups as far as making them hookup/not sway and id like to see what this front end looks like, specially since im not seeing a way around the i beam suspension in the front/seeing a way to do a coilover upgrade. a side/front and underside view of it all would be awesome w/ the tires off if you have any pics laying around. i learn by examination...lol.
This thread is not about my truck but how awesome it would be to have a turbo rotary under the hood. I have a basic four link suspension with a frame notch kit. There are many pics on the net. The front is top secret for reasons that I told my father I would not brag about his custom rod radicalness and that I needed his help.
Does anyone know how well a 13/20b packs up in a ranger?
9000 rpm's ...............
just wanted to see how the rear was made, i realize it isnt about your trk, but i look for information and pics/ideas anywhere i can get them. personally i wouldnt mind finding a similar rotary to the quad turbo 4 rotor in the 787B mazda le mans car that won back in the day. (dont know what engine it is...)
There are guys that put multiple wankels together. I have seen a quad turbo 4 rotor but it was built custom style. I might think that would be a bit much, it would kill in the 1/4 if you can keep it straight! Has anyone ever seen a rotary ranger?
