1354 Electric to Manual Conversion
DeadEye200321
Forum Member
💻 TRS Socials
Arizona
AZ - USA
Vehicle
Drive
4" Super Lift
33"
Hello everyone, I’m on a mission to get a manual transfer case as my electric one is no longer working and I think it’s due to some corrosion as my smart junction box and I don’t want to replace the smart junction box to deal with the crappy electric shift, I want a manual transfer case. As far as I’m aware I found one post about somebody converting there electric 1354 to a manual but that was about it and the details were vague with no photos documenting the process. Does anyone have insight either with pictures or a creation of their own? I was thinking of somehow using the manual linkages from a 1350 to modifying the 1354 case to accept the manual linkages somehow, any help whether it be photos or pictures of there own creation or pointing me in the right direction of who to talk to would be great appreciated, if I can get all the information to do the modification myself I will try and make documentation of it, I have the skills to do it, I just don’t know where to start, so any help is greatly appreciated. Unless someone already has a 1354 manual they would be willing to sell/let go I’d love to purchase that off them and pay for shipping, it looks like making my own manual is the only way to go as I simply cannot find a used manual 1354 anywhere, I’ve checked marketplace, junkyards, eBay and have found nothing. I’ll post the photos of my transfer case housing in the hopes that someone can tell me what things need to be machined/fabricated if people know of a way to make it work. Thank you in advance and let me know if you are selling one and I’ll gladly purchase it from you!
Very spendy...but there is this:
Or maybe use it a concept to make your own actuator on the rear where the motor was vs where the actual manual shift shaft would be.
Like this:
I've thought of making a push/pull cable and modifying the stock gear to have a slot in it then guide the cable around the gear so it could be pushed as well as pulled and make a stick in the cab with detents... if any of that makes sense that is...
I tried this, with hand tools. What you really need is drill press and a jig.
Drill 2 holes slightly undersized and polish for fit is really all that need to be done, IF you have the manual shift parts from a 1350. Both are in the front half case.
1 is the hole that the shift shaft goes through. I did ok on this one even though I couldn't find a large enough drill bit. I used sandpaper on a rod in the drill to enlarge the hole to the right size. A proper drill bit would've been easy and clean. The exterior hole is already started in in the casting.
2 is for the shifter detent. I believe the easiest way to do this one is to drill from the outside but finding the location and squaring the drill is where I failed. I intended to drill through and insert the detent from the outside and install an appropriately sized pipe plug behind the detent and spring.
I wish there where pictures with this link
converting-an-automatic-t-case-to-manual
Cause this sounds super accurate and good but I just can’t envision anything, sadly works can only tell so much
On the newer models it gets even dumber as you would need a new extension housing for the transmission as well since they took the T case shifter bosses off the side which is part of why I was contemplating butchering the shift motor to be cable operated... that and I have an electric 1354 on hand that would be nice to make a range box for my '97 someday when I get bored...
here's a few more pictures.
I made a jig from a manual case. The detent hole is drilled from the outside and I seal it with a 7/16 expansion plug and some sealer. All the manual parts from a 1350 are used except the shift shaft because it is shorter than the 1354m shaft. The 1350 shift shaft could be used but the outside of the case would need to be machined/ground down.
  • 1354 Electric to Manual Conversion
I'd be tempted to buy something like that for my own use...
Though a smart man would probably consider offering a drilling service. Just have people mail you their front case.
I think there are differences in the thickness of the 1354 case where the shift shaft goes or of the 1350 shifter. Mine looked like it would've worked, if I hadn't miss drilled the detent hole.
I would offer to drill them if the 1354m shift shaft was available. Maybe when I come up with a solution for that. I don’t think it’s a good idea to grind down the outside to make the 1350 shaft work. Pic of 1350 shaft on 1354. Too much material would need to be removed to get the locating screw into the guide of shaft in my opinion.
