1330/1310 u-joint question
disciplerocks
July 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
Evansville, IN
I just picked this u joint up from Autozone (part number 1-0134) for my 8.8 swap. I assumed the 2 ends would be long to match the Ex flange, and 2 shorter to match the B2 driveshaft. After opening it, it appears to be the same length on both ends and it is definitely longer than the B2 driveshaft. Anyone have some experience with this swap? I want to stay away from having a driveshaft made.
After some more searching, I think my driveshaft uses 1210 u-joints.
1210s are TINY!
I think a driveshaft swap would be your best bet if that's what you have. 1310 is the normal size used '90-'97. 1330s started appearing in '98 models (which have a little wider cross than 1310).
I figured something out, but thanks for the help again.
