12 bolt oil pan fm-145 compatible swaps 4x4
bobby3146
2.9 V6
4 inch
can yall help me out here so I have a 87 Ranger single cab xlt 2.9 5speed 4x4 I wanna know what all transmissions will work with that and what amount of work would I have to do bc the current transmission in the truck I think its broke lol the the guy I bought it from what trying to float the gears and had everything the between the engine and tranny replaced but when you try and crank it the clutch has to be down even with the truck in neutral and even so the dang thing still try to jump forward like it’s in gear I’m lost guys plz help I’ve already pulled the tranny once not trying to do it again unless someone has some better luck or ingenuity than me lol Ik someone know something thanks in advance
No F bombs... we try to keep it family friendly here.
An M5OD from a 4.0L 4x4 will work.
Isn't the FM145 an inch shorter? Might mean swapping driveshafts too.
I just went over this with @Shran
I have an FM146 and he said it's a direct swap. Same length... bolts to engine and the 1350 manual transfer case in my 86 Bronco II.
I'll have to defer to him on the FM145...
What should I get the driveshaft off of like a extended cab or single cab or what
From the same cab style you have that has the M5OD transmission with 4x4
I am assuming you have an FM-145 right now. Transmissions from newer trucks (FM-146, M5OD) are longer so you will need a longer front driveshaft and a shorter rear one.
For a donor you need to find a truck with the same wheelbase as you have now, with the transmission that you want to use. You may have to do some yoke swapping on your transfer case and/or driveshaft rear most yoke on the shaft itself, not the axle, if you use a donor newer than '89. 89 and older had different and smaller yokes on both ends of the rear driveshaft and transfer case.
There are a few other differences as well with the slave cylinder, floor plate, shifters, etc
