- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
Made an oops with ordering brake parts.
Had a wheel cylinder blow up... and considering that I haven't serviced the rear brakes since I bought the truck about 4 years ago, figured I might as well give it the works.
Since I have a 1995 4.0, assumed that since I had the standard (for the 4.0) 4WABS and an 8.8" rear end, that I'd also have 10" brakes and ordered the shoes, hardware (self-adjust hardware too), wheel cylinders, and rear parking brake cables (one side is bad)... only to dig in today and find 9" drums. Should have known since I've had the wheels off many times... but apparently, I'm an idiot.
Question is, do I return all the stuff I bought to RA and try again, or do I see about getting new (or used) backing plates and drums (Aerostar, of course) and upgrade to 10"?
Also, do the axleshafts need pulled to replace the backing plates, or can I slip them over the hub? Didn't look close enough to tell.
Edit- If I have to pull axleshafts... I might have to put this in it too:
Tempting...
Ford 8.8 LSD Posi Ranger Limited Slip Traction Lok 28 Spline Carrier Inspected | eBay
<p dir="ltr">Ford 8.8 LSD Posi Ranger Limited Slip Traction Lok 28 Spline Carrier. Condition is "Used".</p> <p dir="ltr">Track lok came out of 01 ford ranger, it should fit 93-09 ford rangers, Mazda b-series trucks equipped with 8.8 differential. Item has been inspected, clutches have little...
www.ebay.com
Tempting...
