KeaToN419
I picked up a rear driveshaft from a 99 ranger to put on my 87, the rear flange on the axle is for a 3" bolt spacing and the shaft has a 2 3/4", i knew that was going to be an issue before i bought the driveshaft from reading on here but i cant seem to find the right part to fix this, i was just going to use the yoke from the 87 shaft on the 99 one but i can find the right conversion u joint to do so, 3 5/8 x 2 7/16 or something close to that, so is there a piece on the rear axle itself i can swap out?
