1 in. bl pics?
RangerDork
08 sport ext cab 4x4 prekey. getting 265/75/16's soon. if body lift will be 1 inch. as big as im gonna go with tires so no 3 inch. probably leave the bumpers where they are. does anyone have any pics of how it looks with the extra inch gap between bumper and body? thanks:icon_thumby:
don't ever remember seeing a 1" body lift commercially made. 2" was the smallest and i heard that they may no longer be in production. most now are the 3" body lifts. mine is a 2", but mine is a 1st gen ranger. will look way different on yours.
ok, never seen those before. used hockey pucks on my tracker trail rig, way cheaper. just double check the overall diameter to make sure they match up with your body mounts, then the hole size so they are the same as the bolts size you already have in the mounts. you will probably be needing 1" longer bolts at least. grade 8 or the metric equivalent for sure.
