08 ranger no heat
all of a sudden my heater blows only cold air. AC works fine, fans work fine
but no heat. should I check the coolant?
2 other things>>>>
Is motor comin up to temp?
If not, then its probably the thermostat (BPN# 8575), as they are designed to stick open when they go bad so you don't burn up your engine.
If yes, then its probably the blend door actuator (BPN# 19e616).
