08 Ranger motor mounts 2.3 liter
Kro-Man
North Texas
Hello everyone. My 08 Base Model Ranger has the 2.3l 4-cylinder engine, auto trans. Under load I get a pretty buzzy feedback from the engine. I replaced my trans mount because the original had collapsed. I believe I need motor mounts as well, 155k miles on the odo right now.
The oem engine mounts are on eternal back order at Ford according to a local dealer. I cannot find any online.
My question is; what brands of aftermarket motor/engine mounts have you used and were they direct fit with NO modification required, and did they last as long as the oem parts?
No...no...no.
Rock auto has them and my local stores....was prototyping for an eb swap....
4 whixxer is always buzzy....
No...no...no.
Bobby, I know there are many aftermarket motor mounts. My question is in the original post. Do you have any experience with any of the aftermarket brands?
I had a prior gen Ranger with a 4 cylinder and it did not feel like this one does. Also, the motor moves a lot when starting and under load. So at minimum the rubber is old and is not doing its job. They might not be broken, but I want to replace them anyhow.
Dorman and anchor
Both meh.
