06 sport 4x2
filthy89
i already cranked my tbars and my stock tires are finally meeting there end so ill be buying new tires within the next month or 2. I want to run the largest tire possible without a lift and after doin some research i found lil help. i read that it is possible to fit 32x12.5s M/Ts with triming. but ive never trimed fenders befor so i was wondering what needs to be trimed and what size rim and backspacing to go with it. i also know they will most likley rub on tight turns but nothing i havent dealt with befor. The only offroadin will be dirtroads and getting to the desert. any help would be appreciated
A 32x11.50-15 should fit without trimming IF they're on 15x8 rims with 3.75" backspace. If you're thinking of putting them on the stock rims then they're going to rub on the inside regardless. If you're keeping the stock rims then 31x10.50-15 is the biggest you can go without rubbing.
31x10.50-15 yea bigger tire on the 2006 15x8 rims with 3.75" backspace/vs body lift 2-3 inch /no fender trimming
my truck equip 30x10.5x15
thank yall for the direction.. i really needed the help
i'm looking into gettin the super swamper tsl 31x12.5 on 15x8 steel wheels... sound like a good combo??? if not any other suggestions???
Be kinda loud and ride hard on the road, assuming that's where you'll most of the time in a 2wd. If you want Swampers I would suggest SSR's instead.
