06DangerRanger
Hey all thanks for the help all my previous question about the door swap but now I have a new issue that doesn't involve wiring whatsoever. I lined up my front door and rear door so everything closes and latches properly. The issue I am having is that my front driverside door is not lining up in the groove between the 2 weatherstripping set ups. This causes air to come into my door which after 40km/h becomes really annoying. I tried re-adjusting the door but no luck. I check on the passenger side door and it's fine. My driver door on the other hand it seems like the seal on the door isn't even touching the seal on the cab. Could this require a new hinge kit or am I just aligning it wrong. My rangers an 06 the donor doors came off of an 08. Thanks in advance for the help!
