05 ranger from texas
ceejkay
U.S. Military - Active
Hey guys i just wanted to introduce my self and my truck.. My name is Corey or known every where as ceejkay... my truck is an 05 extended cab and is now in need of some work.. It seems everytime im looking into something it brings me here, so i figured i would register..
So far ive been looking at how to fix my lean, its gotten bad the last couple of months im now at almost a 3" difference.. and went through 1000's of posts look for seat info..
Welcome to TRS! This is just my opinion TIFWIW, but it could be a bad spring in the suspension causing it to lean like that.
i have the same problem everyone here daid its normal for it to lean due to the fuel tank,and weight etc.I used washers a little more under the left coil spring to fix my problem.If you have torsion bars you can crank them up a little to compensate.By the way where are you stationed,i spent some time at Ft.HOOD with 4th IDbefore they relocated and 1st CAV
im in corpus christi right now, just got here this summer actually.. the lean has gotton to the point that i cant stand it anymore.. it seems like springs for these things are hard to find.. i would like a set of oem or 1-2" lift coils.. my truck is only 2wd but i do use it as a truck so lowering is not an option. here is a pic at my buddys house with his new to him toolbox.
what is TIFWIW
