mhall
- Nov 12, 2012
- Automatic
Hi all,
For the last few months (maybe half a year) my 2004 Ranger XLT with the 4.0 L SOHC was running a little bit rough at idle (you could feel it stutter a little, and the tach needle would jump up and down maybe 25 RPMs or so). When I took it in for the 75K service at the local Ford Truck-only dealer last month they said that they thought the throttle was a bit sticky.
I tried to find out from them why they thought it might be doing this but they wouldn't give me a clear explanation of what was happening besides telling me it was sticky and might need a tune-up, and I got really irritated. So then I decided I'd try to take care of it myself instead of trying to get help from people who didn't seem interested in getting to the bottom of the problem.
So I searched quite a while on the net and ended up finding you guys and your incredibly helpful documentation of common issues and discussion threads. So far, I have started by cleaning out the MAF with MAF spray a few days ago which didn't change anything, and yesterday I did that pain-in-the-butt remove the wheel-well job to swap the plugs and wires (thanks again to a discussion thread for revealing the secret to this very tricky job), as well as scrubbing out the IAC with electric spray.
The latest round, swapping the plugs and wires and scrubbing the IAC seemed to help a lot and it is running much, much better, but the idle is still a tiny bit rough. I wondered, how rough is too rough, and how do I decide if the idle is steady enough to be "normal" or if I have more things to check? I was thinking of cleaning the throttle assembly with some intake spray as a possible next move but I wanted to collect some more advice first.
One other question also. Everything has worked great on this car, besides the rough idle, and a seemingly constant need for new front pads and entirely new (NOT machineable) rotors every 1.5 to 2 years, or about 15000 miles, as I don't drive this thing a huge amount of miles. This seems a little weird to me... I don't have to do this nearly as much on most of the other cars I have had in the past. I wondered if it was some kind of design issue affecting all these trucks, such as having rotors that are too small to handle the weight of the truck, or a lack of cooling getting into the wheels and overheating things to cause failure, or if there's something I'm not doing right when I try to follow the factory service guide when I take it to the shop, and I need to change the way I'm getting it serviced.
Thanks,
mhall
Thanks,
mhall
