'04 Ranger front brakes
Olsin6
Okay, so I ordered a Power Stop brake kit from Summit Racing. Double check the application to make sure everything would fit my truck. It said everything was good.
I pull apart my truck, stick all the new stuff on and go to install the caliper bracket. Doesn't fit.:icon_confused: I then look at the rotors. Wow. My current one is 10 1/4 inches. My new ones are about 11 1/4. Is there another set of caliper brackets that I can purchase to run the bigger rotors? Or do I have to spend $60 to ship this things back?
Thanks
2004 Ford Ranger XLT 2wd.
The cheapest route is to return the rotors.
Ford changed the knuckle for the larger rotors.
You could probably find a pair at the auto wrecker, but you'll spend more than $60.
Wasn't the larger rotor change in 2001? Why would my truck no already have this? These are also mounted onto a lift spindle if that changes anything.
Both rotor sizes were available depending on the model, up to at least 2005.
