04+ Blinker Mod
hoosier1104
I'm Awesome!
MTOTM Winner
TRS Banner 2012-2015
Camby, IN
Work hard and play harder
  1. Remove headlight assembly
  2. Remove connector for turn signal of head light housing
  3. R turn signal locate GR/WH wire
  4. Locate the black ground wire for the corner lamp
  5. Cut the black ground wire to the corner lamp leaving enough to splice back together if you go to sell your truck later
  6. Butt splice the ground wire for the corner lamp and put a "T" connector on the GR/WH wire
  7. Connect the 2 wires
  8. Test
  9. Repeat on the other side with the WH/GR wire
The only thing I do not really care for is that when the running lights are on and you activate the turn signal, the corner lamp is 90* out of phase with the headlight assembly. I will see if I can come up with a solution for this.
Pic of the finished product.
nice write up! simple to follow
maybe a small capacitor would help out with the fase issue??
I kind of like it being out of phase. The Focus is like that and I noticed it draws more attention to the signal light than just a regular flash, and more attention to what you are doing is always a good thing.
yeah ive seen it on focuses and escorts
looks a bit out of order tho
