'03 M50D Shifter arm into a '92 M50D?
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
Salem, IN
Will they interchange?
I have a chance to get a FX4 Level II shifter arm if they do.
should. it's an m5od...same trans. should be same shifter base. any chance you have a hook up on another one of those shifters?
Oh, I wouldn't count on that. The top cover went through at least one revision.
It also may matter whether you're talking about the stick itself or the stub.
I see this "it's the same trans" claim all the time. No, not every M5OD is identical. There are several variations. 2WD vs. 4WD. Cologne vs. Lima vs. Vulcan. HD vs. non-HD. and so on. And this situation is thoroughly typical. There are very few transmissions that don't change throughout a run (unless that run is very short). If you want an example, try installing my SM465 into a Suburban or K-series. They came with them for many years, but you'll be in for a nasty surprise.
I know the shaft itself has the lock bolt in different position than mine (I think mine is front to back where the FX4 arm is side to side).
There was one change in the top cover on the M5OD-R1 that is relevant to this issue.
sometime late in 1993 The "Tower" where the stub lever installs into the trans
was made taller by approx 10mm, the "finger" that reaches inside the trans was of course made longer to match.
The FX4 shifter will fit the "tall tower" top covers used from late '93-current,
but not the "short tower" top covers used from 1988-93.
I'm not sure how the aftermarket Hurst shifter accomodates the '88-93 transmissions
or for that matter if it does so at all.... I have enough trouble paying my auto insurance and keeping my gas tank full to seriously consider a $200 aftermarket shifter
AD
