rangerzeal
i cant seem to find a suspension lift for 03 4x4 ranger does anyone know where i could find one
I edited that Johnny to show '96-'01 Explorers instead of '95-'01 Explorers. The '95 Explorer was un-liftable unless you SAS'd it because the rear mounts of the torsen bars where welded to the frame, thus you couldn't use the drop bracket supplied with the Superlift kit or the rear arm mount in the RCD kit.
If you can find a used RCD kit, you can install one of those. RCD stopped making their kit for the '98+ Ranger in early '09.i found that one but i am looking for a coil over swap i should have said that first
Thanks, I didn't know that.I edited that Johnny to show '96-'01 Explorers instead of '95-'01 Explorers. The '95 Explorer was un-liftable unless you SAS'd it because the rear mounts of the torsen bars where welded to the frame, thus you couldn't use the drop bracket supplied with the Superlift kit or the rear arm mount in the RCD kit.
