dfratus
Hello, I want to tow a small camper with my 03, 3.0L extended cab Ranger. Power is an issue. I put a performance chip on the maf sensor and am thinking of exhaust headers. Anybody have recommendations for sparking this puppy up?
People have been looking for bolt on horsepower for centuries. in the old days they added horses , real horses to the wagons.Thanks for the info. I put something called a performance chip on the maf sensor that is supposed to increase power and mpg. Seemed to help some but it also seems like anything that I do seems to help some at first. I'm not wanting to do a lot of expensive mods to this truck. The headers seemed like a reasonable way to gain some hp. I'm having trouble finding some for the 3.0L engine though. Most of them fit a 4.0. I don't know what the gearing is now but if I wanted to change it would it mean changing the whole rear end? I don't have a shop or even a slab to work on. AZ desert back yard is all I have. So I guess the gear ratio would be on the tag attached to the differential cover. I'll be checking it out in the morning. Thanks again. . .
Oh yeah, the truck is 2wheel drive and the trailer is rated at 2000 lbs.
It's a 2K pound trailerWhy should a V6 truck have difficulty with that as long as it doesn't have some huge like 60 sq-ft frontal area on it? (some of the 4-cyl trucks even had 2K+ tow ratings depending on the axle ratio).
I've towed a 4K lbs enclosed trailer up & down the west coast with my 2.9L... I don't know how different the 3.0L power curve is, but with 5-10 more HP (I don't have the '03 spec in front of me) I just don't see why the 3.0L couldn't at least hang with it.
Stopping the thing and sway-abatement are areas of far greater concern with RBVs & trailers (especially with shorter wheelbases like my BII)
I agree with Will and RonD. You probably need to modify your driving habits (let that 3.0 sing once in awhile). Changing rear end ratios may help too, though this would depend on what is currently in there now (combination of your axle ratio and tire size). Swapping the axle whole is generally the easiest way to change ratios if your desired ratio is something that was offered factory. Not hard to do on the ground or in a driveway (get some wood blocks or thick plywood to put your jackstands on if they want to sink down into the ground).
