'03 3.0 in an '05
RangerMax
Moore, OK
I've got an opportunity to buy a 3.0 out of a 2003 Edge for my 2005 Edge (blown engine), but I need to jump on it quickly. Any differences in the engine or tranny (auto) that I should take into consideration, or are they the same (direct swap)?
Is the mileage stored in the instrument cluster, or is it stored in the computer?
Thanks!
If both Rangers have 3.0l engines then yes it will swap over no issues, may want to swap upper intake over if wiring is different, but I don't think it would be
2005 has odometer in both computer and its instrument cluster, if they don't match engine won't start
This was done in 2004 and up Rangers to prevent odometer changes, the cluster was changed to be part of the PATS anti-theft system as well, so it also can not be changed
Google: Ford HEC
HEC = hybrid electronic cluster
Not even Ford Dealers can reset odometers in any model Ford with these new HECs
If a cluster fails they have to get odometer reading from computer, then send that to Ford, Ford programs the new cluster and sends it to the dealer, dealer then has to "marry" the new cluster to the computer for the PATS part
I saw some info online today regarding the upper intake like you mentioned. That's a pretty easy task.
I don't think I'll mess with the cluster or computer. It's not that big of a deal.
Thanks for the reply!
