usaf089
Some bright genius cut the cat off my truck and ripped the wiring out to both the 02 sensors. So now I have the check engine code for both 02 sensors.
They were literally ripped out of there. The only little bit of wiring I can see is about 5 inches hanging off the 02 sensor that's still in the pipe. Anyone have any ideas on how I can go about re-wiring these back up? There is a harness that comes around the top of my transmission, that has a plug (reverse from what I could gather) into the transmission, then some cut wires that looks like it matches one of the sensors.
Does anyone know if this would be it, and if so, for both sensors or just to one? (Not sure if I could splice both of them into this one harness or if there was a separate one for each sensor.
I know this is one of those things where you'd have to see it and I can/have pictures if needed.
