FordRangerFan777
In the last 60 ish days I've noticed a howling sound coming from the rear of the truck. It's getting worse. How much time do I have left before it becomes a catastrophic failure? And how bad can that be if that happens?
Background (context): Around July (2023) I noticed some fluid on my tailgate & rear bumper. In November (2023) I learned this was an indication of a pinion seal going bad. I confirmed the seal was going bad and replaced it (in November). When I did, I checked the fluid and it was a little low (only took about a quart of fluid), but didn't seem low enough to cause concern. I did notice some metal on the bottom of the fill plug. About 60 ish days ago, I began hearing a howling sound from the rear of the truck and in the last week or so it's gotten worse. The truck has ~225,000 on it but the rear axle is a junk yard axle. When I bought the truck, I saw the paint markings on the diff cover and the gear ratio is different than stock for my truck. When I bought the truck (with about 135,000 miles), I drained and put new fluid in the diff. I also noticed metal on the fill plug then too.
I checked the fluid level last week and it was full. Right now I drive about 200 miles / week. I have plans to do an explorer axle swap but had not planned on doing that for another few months.
Couple questions.
1. Am I right to think it's the rear axle causing the sound? Or am I way off? And if so, what do I do to confirm the source of the sound?
2. If it is the rear axle, is there anything I can check? Either what I have already checked or something else?
Couple questions.
