racingranger90
Like title states, I have a 02 Ford ranger with 2.3 duratec and 5sp manual, 2wd... and I'm not getting no power to fuel pump.. I have a few rangers I use for parts trucks. that being said..
(Here's a List of things I've done..)
Replaced and checked all fuses and relays.
Took apart the fuse/relay box and checked the wiring for corrosion... All looks brand new.. no corrosion
Replaced ECU with matching pats key ( thinking theirs a short in the original ECU )
Took bed off, replaced fuel pump with another one that I know is good.. I can jump the fuel pump and here it comes on...
I was thinking maybe theirs a bad ground?.. and I was also thinking that maybe the ECU isn't sending ground to pump due to something bad in the ECU wiring?.. cuz, if memory serves.. I believe the ECU tells the pump to kick on via ground wire..
That being said, my question is , which wires from the ECU go to the pump?.. also, if anyone else has a different theory please shime in.. thank you
