thoorn
- Mar 23, 2014
I have an 02 4.0L that is leaking coolant underneath the intake manifold. I look just behind the thermostat housing, up underneath the manifold, and there is large puddles of coolant. I have found many posts about intake manifold coolant leaks, but it appears that in 01-03, they have a new design for the intake manifold. It no longer has coolant running through it from what I can tell. What else could be leaking coolant under there? There is some sort of electrical connector under there that looks like a sensor of some sort (possible knock sensor) and a plug similar to a freeze plug. I am really hoping it isn't head gasket. The engine runs fine, no codes, good idle, good power, and no smoke that I can see from the tail pipe. Anyone have a similar leak or an idea of what could be happening?
