Ford BBAS link
Featured Build Threads
alwaysFlOoReD
Forum Staff Member
⭐Supporting Member
TRS Banner 2012-2015
Airdrie, Alberta, Canada
'06, '11
3.0L
Here is Fords Body Builders Advisory Service, which has the 2019 Ranger link to dimensions and layout in a PDF format;
https://fordbbas.com/publications
And a direct link to the PDF download;
https://madocumentupload.marketinga...af95d28a009c6bcb1651275208a695506000&v5=False
RANGER
MODEL LINEUP
DIMENSIONAL DATA
SUPER CAB / CREW CAB
PICKUP BOX
SUPER CAB BOX DELETE
AXLE / TIRE / VEHICLE HEIGHT DATA
SUPER CAB BOX DELETE FUEL FILLER PIPE INSTALLATION
CHASSIS CAB / PICKUP BOX DELETE FRAME DATA
WHEEL & TIRE DATA
FRONT SURFACE AREA WORKSHEET
SEAT TRACK & H-POINT DATA
PICKUP BOX DELETE MAXIMUM UNLOADED VEHICLE WEIGHT
(UVW)
ELECTRICAL WIRING
CHMSL CIRCUIT
BOX DELETE TAIL LAMP
Thanks alwaysFlOoRed:
That doc provides a couple tidbits of information:
The wheels are 6 x 5.5; just different than the F-150's 6x135 that you can't swap/use F-150 aftermarket wheels.
And the interesting one for 85_Ranger4x4 and myself - the frame appears to be 3 pieces - front, rear and filler...
Which makes sense if you are using same frame for Ranger and Bronco II - you just shorten the filler/driveshaft/wiring...
But it also leaves door open for either SCab with 5' or 7' bed* or SCrew with 6' or 7' bed by just changing the length of the filler/driveshaft/wiring. (I'll need some better reconnaissance on whether the rear frame is different between SCab and SCrew).
I wonder how pi$$ed the wife will be if I cut the frame the 1st week I have a new truck?
*7' bed would need to be imported from overseas but not impossible.
mine already gave me permission....:shok:
:dunno: who knew...
Upcoming TRS Events
Featured Ranger Based Vehicle
