Shran's '86 Build
Featured Build Threads
When I was looking a few years ago nothing was cheap other than direct replacement.
I finally got mine to seal so I don’t want to rock the boat.
Knock on wood... I think I got it! Maybe it was the full 36 hour cure time on the RTV that was key but I ran it for 20 minutes last night and it hasn't leaked a drop.
I may look at replacing the housing anyway if there's one threaded for a temp sensor. A quick look last night revealed a bunch. I have that stupid T fitting in the lower intake where the heater hose connects to and the temp sensor screws into that. The T fitting itself is 3/4 diameter so I have to use a piece of 3/4 hose and a reducer to get down to 5/8... it would be nice to have just a 5/8 barb fitting there to shorten up the whole assembly.
Clutch seems to be working better, a drive around town will confirm that.
Do you have the 90* housing or the other one?
Mine is the 90*, I can never remember if the application for the one with the port is for a SN95 Mustang or Explorer but the thermostats are different between them too.
Nope... mine's the 45* housing. I think it came with the engine (89 Crown Vic) but it's been a while and I may have robbed it off something else.
Haven't really wheeled this truck in a couple years so I figured I'd take it to our club event again this year. I trail gunned on Iceman (6/10 trail, moderate difficulty) on Friday, led it on Saturday and then my wife took it out on Sunday for the girl's run. Performed well enough but I destroyed a front RCV axle shaft on Friday:
Shran's '86 Build
And destroyed the lockout hub, and the spindle bearing...........
Shran's '86 Build
It was on this obstacle (not my truck obviously) which is not particularly difficult, I just had the wrong line on it, my cab corner got hung up on the big rock, tried to drive up the wall further because I couldn't hear my spotter, then almost tipped over when he told me to keep driving forward :ROFLMAO: Had to winch out, remove the axle shaft, drove back to town and fortunately I had a spare and O'Reilly had a spindle bearing. Back on the road for the rest of the weekend.
Shran's '86 Build
My buddy broke the passenger side tie rod end somehow - just sheared off right by the jam nut. Weird place to break but he had a ready welder so a quick burn back together had him rolling again.
Shran's '86 Build
Everything squeaks and rattles and makes weird noises but it was noticeably worse after Saturday. Somehow all four leaf spring bushings have mostly evaporated? Very odd, they are only 6 years old and still have the stickers on them.
Shran's '86 Build
Also used the crap out of my new M18 inflator. It's perfect for airing up back at camp... one 8ah battery is enough to air up four 35's and four 33's from ~15psi to 30. It will fill a dead flat 35" tire to 30psi in 6 minutes.
Shran's '86 Build
All in all it was a really good weekend. We were at a new campground that everyone was nervous about but it worked out extremely well. I had a blast running my favorite trail, my wife had a lot of fun except the almost tip over moment and she actually did some crawling down a sketchy section unbeknownst to me while I was spotting some other people haha. Truck needs a lot of repairs - hopefully I will have time this winter to mess with it.
Warn won't warranty my broken hubs so I picked up a set of these babies. Spendy but not much else out there besides drive flanges for a 30 spline D44 application. The old Ford hubs of this design were bad ass, I'm sure these will be even better.
In other news I did a bunch of maintenance that was way overdue, which included:
- C bushings
- All four leaf spring eye bushings
- Pulled a bunch of dents out of the cab that were messing with the door strikes
- Wired in a couple new rock lights
- Add-a-leaf on the driver's rear to fix a leaning truck issue
- New power steering pressure hose
- Fixed rear brake hoses that were ripped off their mounts
- New brake master cylinder, I have working rear brakes now for the first time in almost 15 years
- Fuel injectors sent off & cleaned
- Replaced throttle body with one that doesn't stick
- Redid the upper heater hose fitting, Dorman makes one that is angled instead of straight up, huge improvement
- Moved the front clip over about 1/2" so that the body panels line up better and the hood closes straight
- ^ that required me to move the inner cooling fan over slightly
- Replaced the RCV outer shaft that I broke + the "bell" part of the CV joint that RCV made me swap out
- Replaced both driver's side wheel bearings, cleaned & repacked the passenge side
- Cleaned and fixed the Warn hubs that are being replaced
- Swapped out the distributor to rule out a squeaking noise, didn't help
- Cleaned up & painted my spare fuel tank w/ galvanized spray paint, swapped that out and installed a new rollover valve grommet and lock ring seal
- Built a better fuel tank skid plate out of two stock skid plates sandwiched together plus some reinforcements
- Organized my tool box and replaced a few things I either used or lost
Small things left to do. Hopefully I don't let things get this bad again, I've been making a list of things to do "later" for years and it feels good to be somewhat caught up.
Small update - those Yukon hubs are pretty cool. They are sometimes hard to unlock...guessing they get bound up like the old Ford ones do. Have not broke them yet though.
I also redid part of the fuel system. Previously I had the stock two pump setup but I deleted the front tank so that required some fuel line changes and there was way more rubber than I was comfortable with - in fact all of it between the tank and high pressure pump was rubber, and the return line was all rubber (and still is.) I was having some problem with the truck cutting out, dying randomly and backfiring and it ultimately traced back to a very loose external plug on the sending unit. I figured it would be a good time to just remove all the janky rubber hoses... I also deleted the fuel reservoir and high pressure pump, and converted to a single in-tank pump. Used steel brake line from the tank to the filter for the supply side and only have about a foot total rubber in that whole section now.
No more backfiring, no more random stalling out on the highway!
Mixed feels today. First time in almost 15 years that I've had u-joints in the front axle. RCV's are now in my crawler Explorer. Feels kind of like the end of an era.
Also had to switch back to the old Ford locking hubs. I do like those. Warn's suck. Maybe someday I will go back to RCV's in here again - I would just need to buy one ball and one short side inner shaft. I have a spare ball, two outers, and a long side inner.
The goal is to transition this truck totally out of the rock crawling role so bitter sweet in terms of hopefully no more frickin dents and tree damage.
Shran's '86 Build
Shran's '86 Build
Whats the plan for the truck now?
Driving it & enjoying it for now. I keep going back and forth about wanting a different truck that I can use as a "work" truck for lack of better terms. I have been looking for 67-79 Fords or maybe a Dodge that is 4 wheel drive - nothing nice, just a solid beater that I can put a flatbed on and use. I kinda come full circle on that though because I already have this one, so why do I need to replace it when it's probably exactly what I want and I know it inside & out?
I do have a short list of stuff that I need to do though. Maybe this winter:
1. Different wheels & new tires. At least one of the wheels is bent and the tires are pretty chewed up from rock crawling. It would be nice if it didn't shake really bad on the highway. Thinking maybe 16's or 17's this time and Toyo MT's that I can actually balance.
2. Water pump gasket is leaking, should maybe do the timing cover gasket at the same time
3. Might put my old transmission back in. The one I have in there now was supposed to be better but every gear has some little quirk. Looking back, the old one was probably fine and just needs new seals.
4. While the trans is out, I need to inspect the transfer case. Something is rattling a lot at highway speed. To me it sounds like gears that are really worn out and not meshing with each other like they once did. I went through the t-case a few years ago and it had been full of mud and water so naturally nothing inside it is in great shape to begin with other than the bearings I replaced.
5. I may take the lock-rite out of the front axle and go back to an open diff. Unsure yet. I'm not going to drive this in the snow/salt if I can help it but from experience, it's really not very fun to drive in that situation anyway.
6. Possibly might do a ladder rack type thing. It would be cool to be able to haul a ladder or some lumber. With the current bed setup, tool box, and spare tire, it's pretty hard to find a flat spot and tie anything down.
7. I would like to do something else with the tool box and spare tire to free up more bed space. What, I don't yet know.
I feel that. I have 3 single cab trucks with regular pickup beds on them. One should have a flatbed, but I'm not a fan of them. I'd like to get the Ranger into normal use rotation more, but kids man.
For a kid a ride in the Ranger is a fun treat, kids... a standard cab Ranger becomes lawn art.
That's why I built the Explorer crawler. 2 more seats & seat belts is more better. I could never take the kids and wife along on offroad stuff in the Ranger, it was either one kid or my wife.
How people use trucks has changed a lot in the last 30-40 years. My grandpa always had a single cab truck and a 4 door car. My other grandpa had a Ranchero and a car... my parents had single cab trucks and a car. That was always no problem. If you wanted to go somewhere, you took the car.
I think I could probably get away with that too, we usually take my wife's Honda if we go on a trip. I would probably have a single cab Super Duty if I didn't need to have a bunch of tools and towing stuff in it all the time. I can't have a tool box in it because I use it for hauling gravel fairly often and it gets dumped in with a loader. It would get ruined in real short order. So an extended cab, it is.
Same here.
We had a single cab truck growing up. It only had three seatbelts so dad added a fourth set of seatbelts so we would all fit. Four across in a 1981 C-10... not a car seat or booster seat in sight lol.
Eh, more like mines enough of a mutt that I don't want to do daycare drop off with it.
A decent Explorer/B2 has been on the radar for awhile, just need to stop adding to the fleet.
I daily a single cab super duty, daughters car seat stays in it unless my dad needs something. We take the wife's Highlander wherever we go as a family.
We're at a total of 8 vehicles, 5 of which are single cab trucks, 1 is a cab and a half SD parts truck, and I picked up an old cop Expedition that is winter beater daily. Every now and then I envision cutting the Expedition apart for SD axles and 37s, but its such a terrible pile.
Featured Ranger Based Vehicle
