- Sep 19, 2025
- Age
- 55
- Williamsburg
- State - Country
- VA - USA
- Other
- 2007 Volkawagen MK5 Rabbit 2.5
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Total Lift
- None yet ;-)
- Tire Size
- 265/75/16
- My credo
- Facta Non Verba
2011 Sport SOHC 4.0 4wd 5mt
Did Ford use a larger front brake setup in the last few years of production?
There are lots of write ups on using Jeep YJ/TJ/XJ/MJ/ZK wheels.
They all say the 15" fit but you will need to run 2" spacers to make up for the totally different backspacing.
I swapped on a set of 15x8 "Gamblers" today, using Titan Wheel Products 2" spacers.
I have seen Rangers wearing these particular wheels in this forum, in Reddit forums and FB groups so I know they aren't an oddball.
I've got a weird little rub.
The front brake caliper mounting bracket is just kissing the inside of the wheel. I can hear it scraping/squealing when driving forward, oddly not in reverse tho.
I can barely feel a difference between the grooves in the aluminum from manufacturing and where it's rubbing. I've driven about 2 miles.
It's hard AF to get a picture so this is the best I've got.
Whaddya think? Send it and let them "self clearance"?
