Larger Front Brakes On 2011?
cmcolfax
Forum Member
EMT / Paramedic
Firefighter
Williamsburg
VA - USA
Other
2007 Volkawagen MK5 Rabbit 2.5
Vehicle
Drive
None yet ;-)
Facta Non Verba
2011 Sport SOHC 4.0 4wd 5mt
Did Ford use a larger front brake setup in the last few years of production?
There are lots of write ups on using Jeep YJ/TJ/XJ/MJ/ZK wheels.
They all say the 15" fit but you will need to run 2" spacers to make up for the totally different backspacing.
I swapped on a set of 15x8 "Gamblers" today, using Titan Wheel Products 2" spacers.
I have seen Rangers wearing these particular wheels in this forum, in Reddit forums and FB groups so I know they aren't an oddball.
I've got a weird little rub.
The front brake caliper mounting bracket is just kissing the inside of the wheel. I can hear it scraping/squealing when driving forward, oddly not in reverse tho.
I can barely feel a difference between the grooves in the aluminum from manufacturing and where it's rubbing. I've driven about 2 miles.
It's hard AF to get a picture so this is the best I've got.
Whaddya think? Send it and let them "self clearance"?
I ran jeep wheels on my 2010 for a couple years and didn't need spacers at all.. forget what model/year jeep they were off of though.. mabey I can find a picture..
I wouldn't.
Clearance the bracket.
I wouldn't.
I second that. The bracket has more material to lose than the wheel. You're heat cycling that rim in ways it wasn't designed to withstand while slowly compromising its overall integrity.
