- Nov 12, 2018
- Phoenix
- State - Country
- AZ - USA
- Other
- 18 Toyota Camry LE
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.8 V6
- Manual
- Tire Size
- 245/60r14
12° would be with vacuum disconnected at distributor, fully warmed up, and at the correct idle. 30+ sounds about where it should be with vacuum hooked up.bypassed smog pump. truck is running on its own just fine, but it doesnt seem like timing marks are anywhere near close to desired 12 degree mark. more like 30+ BTDC.
any ideas?
ill probably end up going through the timing again and making sure its set right since i have a decent idea of the procedure now.
still adjusting the carb fast idle, its the screw near the choke cam right? and the curb idle is the screw on the throttle plate/cable?
ported vaacuum right? i did initial timing with vaacuum disconnected. i need to swap the hose over cause right now its off of manifold vacuum, been seeing mixed answers but ported vacuum should be where i want it at.12° would be with vacuum disconnected at distributor, fully warmed up, and at the correct idle. 30+ sounds about where it should be with vacuum hooked up.
i seen that, but i feel like shooting compressed air would be a better approach, plus if i do each cylinder one by one with it on compression stroke, i can verify if valves are sealed/ compression if i have bad piston rings.Carbs do not come pre-tuned.
Tuning carb for highest vacuum probably is good idea.
You can use thin rope thru sparkplug hole to hold up valve. Use crankshaft bolt to turn engine to press rope to valve. You will be replacing sparkplugs anyway.
