2.3L ('83-'97) 2.3l
I cleaned and tested injectors. Put it back together and nothing. Had to be a fuel issue because I started it on break clean and it runs great. I guess I’m going to send it to the scrap yard I don’t know what else it could be!
I just reviewed the thread. I don't see wiring to from the injectors mentioned. Computer just grounds them. Do you have power to them with the key on? Note that even the 2.3 has 2 banks. So 2 injector power wires.
I will check that. I ordered a fuel pressure tester to make sure I got the right amount of fuel pressure. Maybe one of my new fuel pumps isn’t pumping good. I will make sure have power to injectors also. My next purchase was going to be a mood light to make sure they’re firing
I have power to both wires at the injectors. What’s my next thing to check?
I don't think I have read anything about checking the fuel pump relay. Swap it with one you know that works.
My test light is only reading 9volts at the injector. It drops while I’m cranking it so I’m guessing they’re getting signal
  • 2.3l
