I have been trying to track this down locally and keep striking out, so here goes:
I have an 89 Super Cab RWD truck which I need to swap to a one-piece driveshaft.
I believe that the driveshaft I need will come from a 1998-2011 RWD Super Cab truck with a manual transmission.
I have a 2000 pinion flange so the larger bolt pattern should be a non-issue, but I will need the rear yoke.
If you have an appropriate driveshaft and you are within a couple hour drive of Detroit, MI / Windsor, ON, let me know and maybe we can set something up.
If you have more specific information about applications that can give me a driveshaft I'll gladly take that info as well.
Much appreciated.
Much appreciated.
