BAD vibration at low speeds
Hampshire, Il
245/70R16
My 1994 2.3 5spd has a BAD vibration whenever I let off the accelerator in any gear. If I push in the clutch, it doesn't seem to do it. Has anyone else had this problem? Im assuming it has something to do with the rear axle
Welcome to TRS
U-joints certainly are a possibility here, but so is a loose rear pinion yoke, also the rear driveshaft center carrier bearing.
Is the vibration more like a humming/buzzing, grinding, or shaking vibration? (or some combination of those?)
Have you gotten under there and looked at things yet?
Welcome to TRS
Its more of a shudder I guess. It feels like something is binding up. I have gotten underneath and everything seems tight. I do also have an ABS and Ebrake light that comes on when I hit the brakes, and doesn't turn off again until I start to accelerate away from a full stop
Good opportunity to go single piece.
Installing the new carrier bearing, and there is this metal dust shield that is just loose on the bearing. I thought when I torque down the nut it would cinch up. It did not. Is it ok to just leave it loose or do I need to take the bearing back off?
This is what it looks like
  • BAD vibration at low speeds
That definitely does not look correct to me...
How did the old bearing come out? Can you tell if something is different on the new one that is preventing it going together correctly? (or was the old one too messed up to tell?)
Isn't that supposed to be like in the middle of the shaft?
The old one was installed the other way around. I thought if I put it on this way that the fat end of the driveshaft would kinda sandwich it together.
you could always just go faster and the vibration would stop
