- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Manual
- Total Lift
- 6
- Tire Size
- 35"
These abstract chunks of metal take a silly amount of time! I did get the transmission crossmember done today though! It even fit when I was done... It's going to be a serious pain in the rear to drop the trans crossmember if I have to pull the transmission but I think if I pull the bolts into the tail housing instead of the nuts on the mount and jack it up a bit it should come out... Still have some steps to do but the only fabrication left involves the O/A torch and press to straighten the steering link...
All the work did pay off, the radius arm bushings are in their neutral point at ride height so that should help the suspension work I hope...
