- Dec 5, 2009
no ac hooked up... Don't really need it here in Hawaii.. If you don't have a/c as well, then I can give you the belt number. Ask for a belt that is a half inch smaller than the belt for the stock 97. I also had to put some washers between the alternator and the block in order to shim out the alternator to get the belt to fit right. Still not perfect, but very close.. I decided not to use the 91 intake. Made a hole in the air duct for the ACT sensor.. Have not dealt with the EVP switch or EGR. Need to focus on that and somevacuum lines that are not hooked up next... The Alternator wires got spliced to fit the 97 alternator. All my wires were spliced when I got the truck all ready. Not ideal, but the truck does run pretty dam good..
